| pgrin |
Dec 18 2009, 10:04 PM
гряземяситель ![]() ![]() ![]() ![]() ![]() Группа: завсегдатый Сообщений: 456 Регистрация: 15-March 06 Пользователь №: 1,359 |
http://www.4wheelnoffroad.com/rokia.html
4X4 2 door "Customized" Toyota axles w/ ARB's , Randy's R&P 5:73 gears, All new bearings in both axles, Diff armored @ both ends, Sky's widening kit, Burfield eliminators, Warn hubs, IFS front calipers w/FJ rotors, Cadillac rear disk conversion, steel braided brake & ARB lines, Custom 3 link rear & 5 link front, full hydro steering, high steer w/chromally tie rod, FJ tie rod ends, 1 1/2 spacers on all 4 corners for wider stance, front welded in truss. 5 - 35/12.5 radial tsl swampers on 15X10 alloy steel true beadlocks. 1 3/8 body lift. Doestec coil overs in front, rear 1/4 eliptic leaf sprung w/ doestec nitro filled shocks. Custom built front & rear drive lines w/ drilled T-case flanges to accept toy drive line ends, double doul cordon rear joints to deal with travel. 1/4" custom fuel tank skid pan. Rock sliders/nerf bars. Tube front bumper w/ stinger & warn 9000i winch, tow hooks & driving lamps. Roof mounted warn spot lamps. Shovels axe & pry bar mounted on inside of rear gate. 2 gallon air tank & ARB compresser. Roof mounted CB. Garmin GPS w/roof mounted antenna. 5 gals fuel & water Jerry cans. Stock floor tool box, extra diamond plate tool box & aluminum parts & fluids box. Less than 18k on the speedo, only 150 miles on it since the build. There are some things left to do to it Rear bump stops & limiting straps E-brake cables rear upper shock mount reinforced gear reduce steering |
| 609 |
Dec 18 2009, 10:32 PM
Заднюю подвеску не осмыслил
Рычаги с полурессорами -------------------- Ротор поля наподобие дивергентсии градуирует себя вдоль спина и там, внутре, обращает материю вопроса в спиритуальные електрические вихри, из коих и возникает синекдоха отвечания.
| aleksandr zaicev |
Dec 18 2009, 10:53 PM
![]() Всепроходимец ![]() ![]() Группа: завсегдатый Сообщений: 50 Регистрация: 9-June 08 Из: Лесной пр. "В начале". Пользователь №: 5,479 место дислокации: САНКТ-ПЕТЕРБУРГ. |
* Эллиптическая — в плане имеет форму, близкую к эллипсу; использовались в подвеске конных экипажей и ранних автомобилей; преимущество — большая мягкость и как следствие плавный ход; минус — технологическая сложность, малая прочность, громоздкость;
* Полуэллиптическая — в виде полуэллипса; наиболее распространённый тип; представляет собой компромисс между комфортабельностью, компактностью и технологичностью, широко распространена на грузовых автомобилях — до сих пор, на легковых — до 1970-х годов; * Четверть-эллиптическая — конструктивно это половина полуэллиптической; как упругий элемент, достаточно жёсткая; применялась как правило для создания независимой подвески, реже — зависимой; находила применение в подвесках таких автомобилей, как ГАЗ-67 (в передней, по две рессоры на борт, располагались продольно), Alvis F-Series (в передней, восемь рессор по четыре на борт, расположены поперечно) или Татра Т77 (в задней, по рессоре на борт, располагались диагонально). |
| 609 |
Dec 18 2009, 11:28 PM
* Четверть-эллиптическая — конструктивно это половина полуэллиптической; как упругий элемент, достаточно жёсткая; применялась как правило для создания независимой подвески, реже — зависимой; находила применение в подвесках таких автомобилей, как ГАЗ-67 (в передней, по две рессоры на борт, располагались продольно) Ну газ-67 я в живую видел Только там рычагов нету... -------------------- Ротор поля наподобие дивергентсии градуирует себя вдоль спина и там, внутре, обращает материю вопроса в спиритуальные електрические вихри, из коих и возникает синекдоха отвечания.
| aleksandr zaicev |
Dec 18 2009, 11:39 PM
на газ 67 роль рычага выполняет рессора
Эскизы прикрепленных изображений |
| 609 |
Dec 18 2009, 11:48 PM
на газ 67 роль рычага выполняет рессора Прикольно Вот помню что рычагов нету - а про вторую рессору забыл -------------------- Ротор поля наподобие дивергентсии градуирует себя вдоль спина и там, внутре, обращает материю вопроса в спиритуальные електрические вихри, из коих и возникает синекдоха отвечания.
| БОБ |
Dec 19 2009, 05:19 PM
[quote name='pgrin' date='Dec 18 2009, 06:04 PM' post='93816']
http://www.4wheelnoffroad.com/rokia.html 4X4 2 door "Customized" Очень интересно. Только с чувством собственного бессилия, у меня такого не будет. Не смогу, даже если бы очень захотел. И даже не в деньгах дело. Могут же , творить . -------------------- Авто 2000 г.в. американец . АКПП. K08A. Уже не мой :(. я на пузотерке , так вышло ....
| alldn |
Dec 19 2009, 08:53 PM
Не понял как устроена поперечная устойчивость заднего моста. Неужели при таких кардинальных переделках оставили панару?
| 609 |
Dec 19 2009, 10:25 PM
Не понял как устроена поперечная устойчивость заднего моста. Неужели при таких кардинальных переделках оставили панару? На самурае при том, что подвеска рессорная - панары в базе есть. И спереди, и сзади. Выкидываются за ненадобностью -------------------- Ротор поля наподобие дивергентсии градуирует себя вдоль спина и там, внутре, обращает материю вопроса в спиритуальные електрические вихри, из коих и возникает синекдоха отвечания.
| CTAC |
Dec 19 2009, 11:05 PM
на газ 67 роль рычага выполняет рессора Полурессора !!!! -------------------- |
| aleksandr zaicev |
Dec 20 2009, 12:27 AM
Рессо́ра (фр. ressort — пружина) — вид демпфирующего устройства, упругий элемент подвески транспортного средства. Рессора передаёт нагрузку с рамы или кузова на ходовую часть (колёса, опорные катки гусеницы и т. д.) и смягчает удары и толчки при прохождении по неровностям пути.
как бы она не выглядела (листовая,торсионная,пружинная) всё равно РЕССОРА |
| Текстовая версия | Сейчас: 18th November 2026 - 05:31 PM |
