| pgrin |
Dec 18 2009, 10:04 PM
гряземяситель ![]() ![]() ![]() ![]() ![]() Группа: завсегдатый Сообщений: 456 Регистрация: 15-March 06 Пользователь №: 1,359 |
http://www.4wheelnoffroad.com/rokia.html
4X4 2 door "Customized" Toyota axles w/ ARB's , Randy's R&P 5:73 gears, All new bearings in both axles, Diff armored @ both ends, Sky's widening kit, Burfield eliminators, Warn hubs, IFS front calipers w/FJ rotors, Cadillac rear disk conversion, steel braided brake & ARB lines, Custom 3 link rear & 5 link front, full hydro steering, high steer w/chromally tie rod, FJ tie rod ends, 1 1/2 spacers on all 4 corners for wider stance, front welded in truss. 5 - 35/12.5 radial tsl swampers on 15X10 alloy steel true beadlocks. 1 3/8 body lift. Doestec coil overs in front, rear 1/4 eliptic leaf sprung w/ doestec nitro filled shocks. Custom built front & rear drive lines w/ drilled T-case flanges to accept toy drive line ends, double doul cordon rear joints to deal with travel. 1/4" custom fuel tank skid pan. Rock sliders/nerf bars. Tube front bumper w/ stinger & warn 9000i winch, tow hooks & driving lamps. Roof mounted warn spot lamps. Shovels axe & pry bar mounted on inside of rear gate. 2 gallon air tank & ARB compresser. Roof mounted CB. Garmin GPS w/roof mounted antenna. 5 gals fuel & water Jerry cans. Stock floor tool box, extra diamond plate tool box & aluminum parts & fluids box. Less than 18k on the speedo, only 150 miles on it since the build. There are some things left to do to it Rear bump stops & limiting straps E-brake cables rear upper shock mount reinforced gear reduce steering |
pgrin Монстр спортяга Dec 18 2009, 10:04 PM
609 Заднюю подвеску не осмыслил :blink:
Рычаги с пол... Dec 18 2009, 10:32 PM
aleksandr zaicev * Эллиптическая — в плане имеет форму, близкую к э... Dec 18 2009, 10:53 PM
* Четверть-эллиптическая — конструктивно это ... Dec 18 2009, 11:28 PM
aleksandr zaicev на газ 67 роль рычага выполняет рессора Dec 18 2009, 11:39 PM
Прикольн... Dec 18 2009, 11:48 PM
CTAC
Полуресс... Dec 19 2009, 11:05 PM
БОБ
[url=http://www.4wheelnoffroad.com/rokia.html]htt... Dec 19 2009, 05:19 PM
alldn Не понял как устроена поперечная устойчивость задн... Dec 19 2009, 08:53 PM
Не понял как устроена поперечная устойчивость зад... Dec 19 2009, 10:25 PM
aleksandr zaicev Рессо́ра (фр. ressort — пружина) — вид демпфи... Dec 20 2009, 12:27 AM![]() ![]() |
| Текстовая версия | Сейчас: 18th November 2026 - 05:25 PM |
